Author Topic: Weather Extremes Script  (Read 734 times)
Offline W Thomas
  • Welcome to my area!
    • Smyth-Grayson Weather
« on: June 04, 2024, 03:12:50 AM »
Is there a script for displaying weather extremes across the US that works with the Saratoga Template Package?
I made a quick search but didn't yield anything promising for the newer sites.
Any suggestions appreciated!
     Best Regards
     Wayne
CWOP CW8217
KVAWHITE22 Wunderground   Davis VUE &  Davis Vantage Pro 2  /   Dedicated Server
Offline hcorrin
    • Ballaugh Weather
Re: Weather Extremes Script
« Reply #1 on: June 04, 2024, 04:25:23 AM »
Offline W Thomas
« Reply #2 on: June 04, 2024, 05:05:44 AM »
Thanks for the reference link.
I have one up and displaying but for some reason it displays Sunday June 02 and doesn't appear to update.
I have two problems with it actually first is the updating problem and secondly, I had a discussion rendering but it was a little too wide for my template page. I need some way to make the discussion image shorter in width. I tried all the code and tags I know and I either crashed the script totally or made no visible change to the image width. BTW the discussion product has now expired
Any suggestions greatly appreciated
https://www.smythweather.net/wxextremes.php
Wt
     Best Regards
     Wayne
CWOP CW8217
Offline hcorrin
    • Ballaugh Weather
« Reply #3 on: June 04, 2024, 06:45:58 AM »
The link is the source code and looks like https://www.hc-iom.co.uk/WD-AJAX1/wxworldextremes.php?extremes=United%2BS#
it may give you some ideas for your page default on my page is UK but set to US to demonstrate what it can show
« Last Edit: June 04, 2024, 06:49:48 AM by hcorrin »
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #4 on: June 04, 2024, 06:17:48 PM »
Wt
copy the entire code here:
https://beaumaris-weather.com/worldextremes_both_units.php?sce=view
then save it to wxextremes.php
then edit the setting within the code for your own country settings etc.  save and put on your website.
Regards Simon
Offline W Thomas
« Reply #5 on: June 05, 2024, 01:12:20 AM »
I will need to set time zone to mine correct??
     Best Regards
     Wayne
CWOP CW8217
Offline W Thomas
« Reply #6 on: June 05, 2024, 01:36:35 AM »
Can't get it to load for me. I might have missed something as it's kinda crazy here at the moment.
     Best Regards
     Wayne
CWOP CW8217
Offline W Thomas
« Reply #7 on: June 05, 2024, 04:59:35 AM »
I discovered the script didn't like my time zone setting of America/New York so changing it to UTC seems to have cured the problem
Thanks for all the help ! One down and ne to go on my problem list :)
     Best Regards
     Wayne
CWOP CW8217
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #8 on: June 05, 2024, 05:29:07 AM »
that's an old version you uploaded
$worldextremesverion = "5.04 - 28-Jul-2020";
« Last Edit: June 05, 2024, 05:35:17 AM by ConligWX »
Regards Simon
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #9 on: June 05, 2024, 05:34:31 AM »
here is the latest version since you have not copied the source from the link provided in many posts.
edit the setting part of the file.  then save/rename to worldextremes.php
Regards Simon
Offline W Thomas
« Reply #10 on: June 05, 2024, 07:41:46 PM »
Ok Sorry about the confusion. I downloaded a version another post suggested and it is working but since it's older I will update that as soon as possible. Thanks for the update on the version
     Best Regards
     Wayne
CWOP CW8217
