It only matters for what the page shows when first loaded (data rendered by PHP tags file). If NO JavaScript is enabled in the browser for that site, then that is what the browser sees.
When the AJAX script starts execution, the feelslike value will change to the heat-index value from the humidex value.
Weather-Display has historically used humidex for feelslike. The weewx plugin replicates that.
In WD, Control Panel, Units, Temperature TAB, you can UNtick "Show humidex instead of heat index or windchill"
The WeeWX change would involve changing the weewxWD python code for the WEEWXtags skin.
For those that wish to change the WeeWX behaviour I've released v0.1.10 of the WeeWX plugin that now includes the ability for the user to specify a simple source observation to be used for the
feelslike tag in
WEEWXtags.php. You can now edit
skins/WEEWXtags/skin.conf and under the banner add an
[Extras] stanza with a
feelslike option as follows:
[Extras]
feelslike = heatindex | windchill | humid | apparent
Setting
feelslike to one of the listed options will use the current value of that observation to set the
feelslike tag in
WEEWXtags.php. If the option is not set or is omitted, the existing testtags multi-source based formula for
feelslike will be used. You can also define an
[Extras] stanza and
feelslike option under
[StdReport] [[WEEWXtagsReport]] in
weewx.conf as follows (note the additional brackets):
[StdReport]
[[WEEWXtagsReport]]
[[[Units]]]
This change will require a WeeWX restart for it to take effect, changing
skin.conf does not require a restart. Note also that placing such settings in
weewx.conf is the preferred approach as such changes survive extension upgrades; changes to
skin.conf will not survive an extension upgrade.
This addition changes the feelslike tag in
WEEWXtags.php only, it makes no changes to any of the clientraw files, Saratoga template files (including javascript).
v0.1.10 of the WeeWX plugin can be found on GitHub
here.
Gary
