For folks in the Southern Hemisphere (Australia, New Zealand, etc.), I know the graph looks wonky -- I'll have to adjust the JPGraph directives to make it look like the Northern Hemisphere graphs.
I did check the calculated data v.s. the USNO and it looks good
check-sunmoon-data.php V1.00 - 26-Aug-2024
..using sunposa.php/USNO data for local times at
lat='-41.428945' lon='148.272474' tz='Australia/Hobart'.
Note: only USNO times coresponding to sunposa.php generated times
are displayed in the following tables
----- Sun data compare -----
Data values are azimuth,elevation
Date: 2024-08-30 2024-08-30
Time USNO data Calc data
06:00 84.5,-7.3 84.7,-7.3
07:00 74.6,3.9 74.8,3.7
08:00 64.0,14.3 64.2,14.3
09:00 52.0,23.8 52.2,23.8
10:00 37.9,31.8 38,31.8
11:00 21.2,37.4 21.2,37.4
12:00 2.4,39.7 2.4,39.7
13:00 343.4,38.3 343.3,38.3
14:00 326.0,33.5 325.9,33.5
15:00 311.2,26.1 311.1,26.1
16:00 298.7,16.9 298.6,16.9
17:00 287.8,6.7 287.7,6.5
18:00 277.8,-4.4 277.6,-4.4
----- Moon data compare -----
Data values are azimuth,elevation[,illumination if available]
04:00 59.0,-7.4,0.17 54.4,-7.5
05:00 49.7,1.8,0.17 45.6,1.4
06:00 39.3,9.2,0.17 36.5,9.1
07:00 27.6,15.2,0.16 26.5,15.1
08:00 14.7,19.3,0.16 14.6,19.2
09:00 1.1,20.9,0.16 1.1,20.8
10:00 347.3,19.8,0.16 347.3,19.7
11:00 334.1,16.3,0.15 335,16.2
12:00 322.1,10.7,0.15 324.7,10.6
13:00 311.4,3.5,0.15 315.3,3.2
14:00 301.7,-5.4,0.14 306.2,-5.4
it's just that the azimuth map to a X scale that is not 40 to 320 but centered instead on zero. I'll keep trying to make it adapt, meanwhile, I suggest holding off on the update (at least the wxastronomy.php) until I can get sunposa.php fixed.
