The start up seems ok including WLL Health, but then it starts to miss a WLL broadcast.
2024-08-24 11:06:47.410 Normal running
2024-08-24 11:06:47.411 GetWllCurrent: Delaying 200 ms
2024-08-24 11:06:47.415 WLL Health: Get WL.com Historic Data
2024-08-24 11:06:47.415 WLL Health: Downloading the historic record from WL.com from: 2024-08-24T10:50:47 to: 2024-08-24T11:06:47
2024-08-24 11:06:47.415 WLL Health: WeatherLink URL = https://api.weatherlink.com/v2/historic/103186?api-key=API_KEY&start-timestamp=1724511047&end-timestamp=1724512007
2024-08-24 11:06:47.535 WLL Health: WeatherLink API Response: 200 - {"station_id_uuid":"4fd4f676-86d1-440e-9fc1-6a3b6806ae4a","sensors":[{"lsid":621849,"data":
2024-08-24 11:06:47.541 WLL Health: Found 6 sensor records to process
2024-08-24 11:06:47.581 WLL Health - found health data for ISS device TxId = 4
2024-08-24 11:06:47.582 WLL Health: ISS 4: Battery state is OK
2024-08-24 11:06:47.582 WLL Health: ISS 4: Errors=1, CRCs=1, Resyncs=0, Streak=97, %=99, RSSI=-78
2024-08-24 11:06:47.582 WLL Health - found health data for ISS device TxId = 1
2024-08-24 11:06:47.582 WLL Health: ISS 1: Battery state is OK
2024-08-24 11:06:47.582 WLL Health: ISS 1: Errors=0, CRCs=0, Resyncs=0, Streak=21, %=95, RSSI=-76
2024-08-24 11:06:47.582 WLL Health - found health data for WLL device
2024-08-24 11:06:47.591 WLL Battery Voltage = 5.7V
2024-08-24 11:06:47.591 WLL Input Voltage = 4.67V
2024-08-24 11:06:47.591 WLL Uptime = 68d:18h:07m:20s
2024-08-24 11:06:47.591 WLL WiFi RSSI = -43dB
2024-08-24 11:06:47.591 WLL Link Uptime = 0d:05h:50m:46s
2024-08-24 11:06:47.591 WLL FW version = 2021-11-05
2024-08-24 11:06:47.591 WLL Health - found health data for ISS device TxId = 2
2024-08-24 11:06:47.591 WLL Health: ISS 2: Battery state is OK
2024-08-24 11:06:47.591 WLL Health: ISS 2: Errors=0, CRCs=0, Resyncs=0, Streak=21, %=95, RSSI=-82
2024-08-24 11:06:47.621 GetWllRealtime: Sending GET real time request to WLL: http://192.168.1.65/v1/real_time?duration=1200 ...
2024-08-24 11:06:48.803 WLL failed to get broadcast port via real time request, defaulting to 22222
2024-08-24 11:06:48.803 WLL Now listening on broadcast port 22222
2024-08-24 11:06:51.811 WLL: Missed a WLL broadcast message. Percentage good packets 0.00% - (1,0)
2024-08-24 11:06:53.858 WS Client Connect: ::1, Total clients: 1
2024-08-24 11:06:54.820 WLL: Missed a WLL broadcast message. Percentage good packets 0.00% - (2,0)
2024-08-24 11:06:57.831 WLL: Missed a WLL broadcast message. Percentage good packets 0.00% - (3,0)
2024-08-24 11:06:58.386 Exiting system due to external: Close Main Window
2024-08-24 11:06:58.388 Cumulus closing
2024-08-24 11:06:58.388 WLL broadcast listener stopped
This may be an issue for CumulusMX developer Mark at the Cumulus forum unless he checks in here. However looking at the MXdiags, your settings are that you are using station type 11 Weatherlink Live, but I also see Weatherlink Console mentioned. Do you have the Weatherlink Live device 6100 or the Weatherlink Console device 6313?
Did you make any setting changes to CumulusMX after your PC was restarted?
Enjoy,
