Author Topic: WS-5000 console SD card?  (Read 276 times)
Offline wd40
« on: August 31, 2024, 03:41:07 PM »
I installed a Sandisk 16 GB micro SD card into the console.  I have a couple of questions that searches have not found the answer.
1.   What format for the SD card?
2.   I got a green SD memory card icon on the console display.  Does that mean the card is working as it should?
Offline kheller2
Re: WS-5000 console SD card?
« Reply #1 on: August 31, 2024, 05:07:15 PM »
From the FAQ: "microSD card (SDHC, max. 32GB, FAT32)."
Green means the card is recognized.
Ambient Consoles: WS-2000, WS-1900, WS-1200, WS-2902C, WS-3000-X3, WS-0900-IP(observerIP), WS-1001-WIFI
Ambient Arrays: WH65B
Ambient Sensors: WH31E(3), WH31B(2), WH32B, WH31SM(2), WH31PGW, AQIN, WH31LA(3)
Ambient Spares: WH24B(2), WH25B.
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Gyvate
« Reply #2 on: August 31, 2024, 07:21:16 PM »
there is a lot of information about the HP25x0/WS-2000/WS-4000/WS-5000 consoles at
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#hp2550_hp2560_-_ambient_ws-2000_ws-4000_ws-5000_-_froggit_hp1000pro_se_hp2000
and as for the SD card and data saved at
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#data_export_from_the_hp25x0_console
WS2350 1.6.7, GW1000(3) 1.7.7,WH2650 WiFi (2) 1.7.7 (test/backup), GW1100 2.3.4, GW1200 1.3.2, GW2000(3) 3.1.4, HP2551 1.9.7,5.1.6;HP3500 1.7.2,WS3800 1.3.0, WN1910 1.2.3,WN1980 1.2.3;
Ecowitt WS90(2)1.4.3/1.4.0, WS80(2)1.2.8, WS68, WS69, WH40,WH31,WH31-EP,WN30,WN34L,WN35,WH32,WH32-EP, WH32B, WH57 [Lightning], WH41[PM2.5], WH51, WH45, WH55
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpecRad02
weather landing page: http://meshka.eu
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline wd40
« Reply #3 on: August 31, 2024, 10:34:16 PM »
Thanks again for the help guys. [tup]
I went through all the ambeient FAQ but must have overlooked the format one.
I should have remembered your pages Gyvate
