I am interested in buying a 6372 unit to add to a Vantage Pro2. The purpose would be to use an IR (infra-red) temp sensor with the 6372.
I can't seem to find the specification for the Davis temperature sensors, so I can source / build an IR sensor that is compatible.
Any help on either compatible IR sensors or the specs of base Davis temp sensors so I can source an IR sensor would be much appreciated!
